HELP H22 BASE MAP NEEDS LOOKING AT
Az786
Post by Az786 »
HI, I HAVE A H22 WITH EURO R INTAKE THROTTLE AND 310 INJECTORS, TRI Y MANIFOLD 2.5 STRAIGHT TO THR REAR. CAN SOMEBODY LOOK AT THE MAP AS IT IDLES FINE BUT HAS NO TORQUE TO VTEC AND WHEN V TEC INGAGES IT PULLS VERY HARD.
DATALOG AND CALIBRATION ATTACHED
THIS IS MY FIRST ATTEMPT TO RECORD A DATALOG AND POST IT SO IF THERE IS SOMETHING I HAVENT DONE LET ME KNOW
THANKS
Re: HELP H22 BASE MAP NEEDS LOOKING AT
Since this is just a base map, it will need to be properly tuned on the dyno to get the maximum potential out of it.
Az786
Post by Az786 »
Okay, the problem I have is the h22 base maps on the manager will not run on my setup as I have a Euro r intake injectors setup, can you adjust the h22 base map to suit my setup UNTILL mapping session?
