IDLE papameter issue it did not take effect.
bian.yy
Post by bian.yy »
I have programmed this calibration to my ECU with one issue.
The actual idle speed is not what I set in cal. I set it to 700 and it runs on 800 actually, checked by hondata mobile app.
Re: IDLE papameter issue it did not take effect.
Without the calibration and datalog it is hard to say what it might be.
bian.yy
Post by bian.yy »
Spunkster wrote:Without the calibration and datalog it is hard to say what it might be.
Please refer:
Start.fpcal
There is no datalog posted.
bian.yy
Post by bian.yy »
Spunkster wrote:There is no datalog posted.
Sorry for that,here you go.
2 with 0708 injector lower 0001.fpdl
2 with 0708 injector lower 0002.fpdl
What year vehicle is this and what exactly has been done to it?
bian.yy
Post by bian.yy »
Spunkster wrote:What year vehicle is this and what exactly has been done to it?
05tsx stock plus 07 flashpro.
I only see it idling for about 20 seconds in these datalogs.
The stock equivalent calibration has an idle set to nearly 800. It probably is not a good idea to try to idle it lower than stock as this can cause low oil pressure and also a lot of additional vibration.
bian.yy
Post by bian.yy »
Could you check why this setting dosenot work, I need this function to be fixed.my car is automation tranny.
Have you tried the idle learn procedure?
With the engine completely warm and everything turned off (ac, audio, lights, etc.), let the car idle for 5 minutes without touching the throttle. IF the fans come on, do not include the time they are on in the 5 minutes.
bian.yy
Post by bian.yy »
Please refer the 10 minute idle datalog.
bian.yy
Post by bian.yy »
Spunkster wrote: Thu May 18, 2017 3:03 pm Have you tried the idle learn procedure?
I followed it please check the datalog in above post.
bian.yy
Post by bian.yy »
Is there any update?
