Can kpro control the cable throttle IACV ?
chukhchukh
Post by chukhchukh »
Can kpro control the cable throttle IACV ? Since i am using the krpo v3 connect aftermarket dual ecu hardness for my japanese cl7R(cable throttle). I found that the idle speed is too high(over 1000rpm) and redeuce very slowly to 850rpm everytime i open the throttle even i replace a brandnew IACV. Because now i had disable the idle control function in kmanager (when i click this function on, idle air control error code will on) . So i want to know that is kpro can not control the cable throttle IACV and only for the electric throttle? Thank a lot
Re: Can kpro control the cable throttle IACV ?
You are using K-Pro on an unsupported vehicle and may experience problems such as this.
