I really need you to help on this ATOM problem
NuclearAtom
Post by NuclearAtom »
I was following these two old topics & my lead was in the dead end.
I was wondering what solution they did to this problem. I have the exact problem and I was frustrated and ATOM can't help
and Hondata always telling me to go to Atom. Pointing fingers back and forth is not productive and not helpful.
I tried to reach the tuner who has this problem (jcnicolin and dbwy111) but i'm not allowed to pm in the forum.
I need help, my atom will start and will die seems the same issue in the immobilizer. I bought the flashpro from Atom too.
I keep emailing atom and no one seems to give me a definite solution -- they were telling me to talk to hondata and refutable tuner.
Please kindly read this two topics: maybe someone here might be able to ring the bell.
Thank you so much.
http://www.hondata.com/forum/viewtopic.php?f=44&t=17126
http://www.hondata.com/forum/viewtopic. ... 740#p73740
Re: I really need you to help on this ATOM problem
Where are you located? Where did you get your FlashPro? The FlashPro for the Atom is special, and can only be purchased through TMI or Ariel.
NuclearAtom
I bought it from TMI...
can you explain to me why it did not work?
Is it because the immobilizer in flashpro has to be disabled by hondata before it can be used by the atom user?
In misc-parameter the immobilizer data cannot be changed. Is this the reason?
Is this a fluke error from you that you did not turn the immobilizer off before sending it to me?
What do i do next?
Email support@hondata.com with the serial number.
