S300 v2 solid cel car won't start
TeGgYBwOi
Post by TeGgYBwOi »
Car was tuned back in September everything worked fine til last weekend went to the track unloaded off the trailer drove to staging lanes and bang car won't start anymore 2 green lights come on initially then the USB flashes red once other light stays green... I pulled the s300 and put it in my bone stock eg and it starts but cel stays solid anyone else have this problem? Could it be possible that it reset itself? Cause I'm almost a thousand percent sure that car tuned for id 1000's isn't starting a bone stock car... please some input shit driving me nuts
Re: S300 v2 solid cel car won't start
Can you datalog? Have you tried re-uploading your calibration to the ECU?
TeGgYBwOi
Post by TeGgYBwOi »
Spunkster wrote:Can you datalog? Have you tried re-uploading your calibration to the ECU?
Yes I have to disconnect/connect the battery reupload the tune car starts and idles as it should but if I turn the car off and then go to start it again same problem
TeGgYBwOi
Post by TeGgYBwOi »
Spunkster wrote:What is the serial number that is on the s300 board inside the ECU?
At work right now is there any other way to get that info? It is registered
No, you will need to look on the board inside the ECU.
TeGgYBwOi
Post by TeGgYBwOi »
Spunkster wrote:No, you will need to look on the board inside the ECU.
Ok I'll post it up later
TeGgYBwOi
Post by TeGgYBwOi »
23063
So is it having the problem with having to upload in the race car and the stock car?
TeGgYBwOi
Post by TeGgYBwOi »
Spunkster wrote:So is it having the problem with having to upload in the race car and the stock car?
I mean I have to pull the battery n load map every time I wanna start the car
but is it doing the same thing on both vehicles?
TeGgYBwOi
Post by TeGgYBwOi »
Spunkster wrote:but is it doing the same thing on both vehicles?
Yea solid cel in both only difference is it'll start the stock car with the solid cel but won't start the race car without the extra stuff
TeGgYBwOi
Post by TeGgYBwOi »
Spunkster wrote:From Help, About, what is the version of software you are using?
The newest version
what is the actual version number?
