Aem wideband
pipodeluna
Aem wideband
Post by pipodeluna »
I'm using the aem analog wideband connected my flashpro for 2 months and suddenly stopped working on FP sensor display :( all wire connections is good. Anyone experiencing this problem? TIA
pipodeluna
Re: Aem wideband
anyone how to resolve the problem?
Re: Aem wideband
What vehicle, what version of software?
pipodeluna
Re: Aem wideband
Civic si 2008
Flashpro manager 2.4.9.0
Re: Aem wideband
Post your calibration and a datalog showing the issue.
Pipo
Re: Aem wideband
Post by Pipo »
here's my calibration and datalogs
Re: Aem wideband
according to the datalog there is no voltage being input. Have you used a multimeter to check the voltage from the wideband?
pipodeluna
Re: Aem wideband
you mean the white wire (0-5 voltage input) ?
Re: Aem wideband
Whichever is the signal wire from the wideband.
pipodeluna
Re: Aem wideband
Here's what I've got on the analog output wire (white wire)
Re: Aem wideband
Is it a constant 2.27 volts at all times?
pipodeluna
Re: Aem wideband
Yes
Re: Aem wideband
If it is a constant voltage you either have a bad sensor, or the wideband controller is damaged.
pipodeluna
Re: Aem wideband
I've tested it in a new wideband & sensor still not working :(
Re: Aem wideband
I would recommend that you contact AEM for assistance with why the output voltage is not changing.
