coilpack issue
kamtuned
coilpack issue
Post by kamtuned »
ive been dealing with this issue all night and cant figure out what is causing this issue its like misfire
car has a B20Vtec fully built previusly had 240whp with no issues at all then went to cpr kit and ramdonly makes this like misfire
kamtuned
Re: coilpack issue
Post by kamtuned »
this is the dyno graph
Re: coilpack issue
What spark plugs are you using?
kamtuned
Re: coilpack issue
Post by kamtuned »
bkr9eix wgap is like 45
Re: coilpack issue
Is this an OEM or aftermarked distributor?
kamtuned
Re: coilpack issue
Post by kamtuned »
it was running ok before cpr, is a new dizzy from xenocron
Re: coilpack issue
but is it OEM, or aftermarket?
kamtuned
Re: coilpack issue
Post by kamtuned »
it is aftermarket i think
Re: coilpack issue
We have seen a lot of problems with aftermarket distributors. Try using an OEM one and see if that resolves the issue.
