P1166 05 rsx type s primary o2 sensor stuck at 0.00v and -37.00A
vaultrsx
Post by vaultrsx »
I thought this problem was due to a faulty o2 sensor so I replaced it with a 02-04 type s af sensor and it still gave me p1166 with no reaction at all so I removed the 4 pin connector and turned the car on to see if the error would continue or if it would give me another. Threw a p1166 still even with af sensor unplugged. So then I checked resistance of the sensor and it was in specifications s l I tried another kpro on my car and voltage and current was read finally and my af ratio was correct too. I put my ecu in their car and it threw a p1166 what could be wrong. I know the ecu carries the problem otherwise it wouldn't have hopped to the other healthy car. What is the likely cause I got this as a birthday gift and I want to know warranty or any help from the admins please. It would be much appreciated.
Re: P1166 05 rsx type s primary o2 sensor stuck at 0.00v and -37.00A
It sounds like the ECU is damaged. The ECU is not covered under any warranty. If you need to swap the K-Pro to a working ECU it will be $150 to do so and you will have to supply the working ECU.
Send and email to support<at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
include a link to this post.
vaultrsx
Post by vaultrsx »
Thank you for the reply! Will do.
vaultrsx
Post by vaultrsx »
Also the serial number on the side of the ecu?
