b16a map issue
kevin-46
b16a map issue
Post by kevin-46 »
i have hondata s300 v2 its my mates it was set up on stock b16a i used it in my car and it was good map but yesterday it was haven a problem when i put my throttle all the way down it cuts out and after 2.5k revs its fine i had the ecu hooked up to my pc but i didnt change the map .
Re: b16a map issue
without a datalog showing the issue it is impossible to speculate on what it might be.
kevin-46
Re: b16a map issue
Post by kevin-46 »
only new to honda its just weird that it was working then stoped when i only changed the lunch control and some one take a look at that map please
Zperformance
Re: b16a map issue
Post by Zperformance »
Try disabling launch control. Reupload a new map and see if you are able to datalog. Is check engine light on?
