Help! Parameters/Fuel Injectors tab - not possible to save
Maverik
Post by Maverik »
Civic Type R Turbo (EP3) - K20A2
K-Pro 4 - PRA ECU - K-Manager 4.3.1.0
Hondata Injector Driver
Staged injection - 310cc (gas) + 1000cc (E100)
The following parameters are not saved in the map:
- Staged injection (secondary injectors) Enabled
- Injectors voltage comp (dead time) quick select
- Staged injection activation - RPM & Load
- Staged injection output control
.... I believe there is a bug!
Re: Help! Parameters/Fuel Injectors tab - not possible to save
Yes, it was a bug. Thank you for pointing this out. We will make a release tomorrow morning to fix this.
