AFR's fluctuating
redyute
AFR's fluctuating
Post by redyute »
99 ek A3 swapped kpro v4. My afr's act like idle serge will go from 11 to 22 back and forth at idle or even while driving. I uploaded a fresh map from scratch thinking it was my current tune which had the problem but I'm getting the same issue, any ideas what the issue can be? I can post an idle log but I really cant drive her to far like that.
Re: AFR's fluctuating
You might have an exhaust leak.
redyute
Post by redyute »
Spunkster wrote:You might have an exhaust leak.
a leak before the wideband 02 can do that? ok I will check it out tomorrow when I get off cause I actually do think I have a leak
redyute
Post by redyute »
Haven't had to much time to mess with the car but today I was doing some checks, no exhaust leak. Looking at sensor data 02 voltage is 0, have my wideband wired to analog 0, its shows afr's values instead of voltage. Would my next step be to measure voltage output from the controller?
You could try doing that.
redyute
Post by redyute »
So after calibrating the 02 sensor it started responding normally again no more fluctuations.
