Code p1164
jeremynei
Code p1164
Post by jeremynei »
Hey guys I really need help I have a 2005 Acura rsx type s with a k20z1 head and a k24 block and the code p1164 keeps coming up for a slow air/fuel ratio sensor response. I have changed my Air fuel ratio sensor but the code is still there if I delete it while driving it goes away for a good amount of time but will still eventually come back. I do have kpro but idk if that has something to do with it. Any help is appreciated thank you.
Re: Code p1164
Are you using the 02-04 o2 sensor, or the 05 o2 sensor?
jeremynei
Re: Code p1164
Post by jeremynei »
It should be the 05 it's a denso sensor I bought off of of k series parts
Re: Code p1164
You cannot use the 05 sensor with the K-Pro. You must use an 02094 sensor as it states on the page form the 05-06 K-Pro.
https://www.hondata.com/kpro/kpro-0506-rsx
jeremynei
Re: Code p1164
Post by jeremynei »
Thank you so much I should have read that better I will use the 04 sensor and see if that works :)
