FN2 calibration to KPRO
janiscrulzz
Post by janiscrulzz »
Hello. i have kswap civic ek with FN2 engine. i am using ep3 ctr wiring, ecu (PRA) throttle by cable.
i am uploading in kpro calibrations fro CIVIC TYPE R (european) PRA k20a2 but car drives terrible.
Iam did fuel adjustments not to rich or lean fuel is ok. when i start to drive engine on small revs dose not fell smooth, 1000-2000rpm.
is it possible to upload stock fn2 flashpro calibrations on kpro?
maybe someone can post pictures of ignition, cam angle, fuel maps ?
thanks.
Re: FN2 calibration to KPRO
There is no way to use a FN2 calibration on a K-Pro. The engines really are not that different. I would recommend proper dyno tuning to get it running correctly.
typer86
Post by typer86 »
janiscrulzz wrote:Hello. i have kswap civic ek with FN2 engine. i am using ep3 ctr wiring, ecu (PRA) throttle by cable.
thanks.
Download FlashPro Manager and load the stock FN2 RSP cal... So you can see all details what you requested.
