Launch control activated in normal driving
mladjan
Post by mladjan »
Hi,
I experienced once that launch limiter is activated after track day (probably clutch was under fire still), tomorrow was everything ok.
Today I mounted a new clutch and I experienced the same problem. Car doesn't rev more then 6.5k rpm (where launch control is set).
What Flashpro use as "switch" for clutch pressed?
Why is this happening?
Re: Launch control activated in normal driving
It uses the clutch switch.
mladjan
Post by mladjan »
Can be clutch switch be affected with new clutch? Not sure where this switch is located?
IT is located in the pedals assembly. You usually have to adjust the pedal when installing a new clutch, so it is very possible it is the clutch switch.
mladjan
Post by mladjan »
It happened tonight again, but I checked and I think its not connected to clutch. Clutch is new, not slipping at all. Its probably bug in the software.
I was driving one hot lap, and after that stoped on 2min to change a driver. When my friend started to drive, it was going only up to 5-6k rpm. Stopped the car, started again, the same. I had a flashpro in my glovebox compartment, fleshed the car with the same map, and it worked.
Behaviour was the same like previous time (when I created this thread), it was after a hot lap, and when I wanted to start driving home. Maybe this is some kind of safe mode?
How can I help you to debug this problem?
From Help, About, what version of software are you using?
mladjan
Post by mladjan »
I think its latest stable: http://cloud.mladjan.me/1m1i2w393E1P
What does it say for the version number when you click on Help, About?
mladjan
Post by mladjan »
2.4.9.0
That is old software. Download the most recent version of software from the software section of the website, upload your calibration to the ECU using that version and see if the problem persists.
