Add bluetooth feature to non bluetooth hondata
adbodykits
Post by adbodykits »
Hi friends. I have a P28 with Hondata S300 without bluetooth feature, just the usb cable for dataloging.
I wonder if its possible to plug an usb-bluetooth device to that cable, and use the android hondata app to retrieve the ecu data???
Re: Add bluetooth feature to non bluetooth hondata
USB is a master/slave technology. The s300 is a USB peripheral or slave, and must be plugged into a USB master like a laptop. A USB-BT device is also a slave, and will not work unless plugged into a USB master. Even if that worked, the USB-BT would need to know the polling protocol for the s300.
We do offer an upgrade for earlier s300 customers.
https://www.hondata.com/downloads/s300v ... e_form.pdf
