Engine Idle B18C2 - AC Compressor & Radiator Fans
Lyle_57IAL
Post by Lyle_57IAL »
Hello Hondata,
Currently having difficulty setting a smooth engine idle on a B18C2 GSR Turbo with AC still retained and full size radiator.
When idleing - when the AC turns on the car will drop in rpm by approximately 200rpm and lean out from around 14.5 to 16.5. Obviously from the extra load on the engine from the compressor. Is there anyway to compensate for this when building a tune ? also this seems to be the same concept with the radiator fans, just the magnitude no so much.
Any feedback would be great
Cheers
Re: Engine Idle B18C2 - AC Compressor & Radiator Fans
Do you have the correct injector dead times entered into the software for the injectors you are using?
