Idle is very lean!?
R-12914
Idle is very lean!?
Post by R-12914 »
Hi Hondata,
if i run my FN2 s/c on idle with or without A/C, the engine runs very lean at about +9/+13 s.trim, closed loop lambda is correct @1.00:
Idle and s.trim with A/C on:
Idle and s.trim with A/C off:
Is it possible to make the Idle more rich or what is a optimal idle-s.trim value?
Thanks!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
R-12914
Re: Idle is very lean!?
Post by R-12914 »
Hondata,
any news about this?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
My Car is a FN2 with Rotrex C30-94 Supercharger and RC 750CC Injectors.
I have made a another datalog.
The idle you can see at the end of the datalog.
Please take a look on it!
The Map and Datalog see below!
MS_RotrexC30-94_4BAR-HYBRID_06-01-2017.fpcal
Datalog#1_06-01-2017_Run-Pulls-Idle.fpdl
Datalog_warm_IAT-NEU_Idle.fpdl
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Has this been properly tuned on the dyno?
R-12914
Post by R-12914 »
Spunkster wrote:Has this been properly tuned on the dyno?
No, on the road!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
It may have something to do with the manifold design. Have you discussed the issue with a professional tuner?
typer86
Post by typer86 »
I have the same kit mounted. With my old RC 750 injectors and the little 650s... Strim was 0 or little rich but never +10 or higher...
With my dw800 and the tts layout all good.
Did you have no idea what could be wrong? Maybe bad injectors, fuel pump, o-rings?
typer86
Re: Idle is very lean!? /resolved
Post by typer86 »
Spunkster wrote:It may have something to do with the manifold design. Have you discussed the issue with a professional tuner?
SOLUTION found
I found the issue for this case.
Deadtimes of the RC750kit which is mounted is unfortunately to high. (We used the deadtimes from your RC750 starting calibration but tests confirm that it does not match for this kit... Total creazy because other kits which I have seen working fine with your default values...)
So we are currently determine the correct value for this injector kit so we can say the idle + low load the S.TRIM values will be the same...
Update: MAF sensor is going bad... Adjusting the deadtimes does not fix this effect as expected.
First check with an other MAF - the readings AFMflow Volts are OK - new part is ordered...
R-12914
Post by R-12914 »
No, the problem was a leak (o-rings) of the injectors (manifold-sided).
The problem was solved with new seals together with new ASNU (customized) injectors!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
R-12914 wrote:No, the problem was a leak (o-rings) of the injectors (manifold-sided).
Additional:
The black pipe which is connected to the rotrex was not sealed completely which cause wrong air passed the MAF sensor...
After fix the air leak, XY s.trim vs AFM.c curve looks perfect.
