PRA wideband Install?
JackSVM
Post by JackSVM »
Hi I'm new to this forum, Iv nearly finished my boosted k20 ep3.
I'm wondering can I use my AEM wideband lambda and wire it into the ecu ?
The car will be used/modified/raced/data logged regularly so I need to know my af's are sweet.
Jack
JackSVM
Re: PRA wideband Install?
Post by JackSVM »
Iv got Kpro on my PRA ecu btw.
What KPro do you have?
JackSVM
Post by JackSVM »
Kpro4
JackSVM
Post by JackSVM »
Sweet !
That's exactly what I was hoping for.
I can also wire my other AEM sensors in This way aswell then can't I? (Oil pressure/temp and water temp)
correct
aaron johnson
Post by aaron johnson »
Ok. So I'm new to the kpro and in fact to computerised cars.
I've got an s2000 which I've fit a kpro4 to which I'm running in scca e production.
I have an aim evo4 data logger hooked up to the digital inputs using the can wires. I'm looking to switch from the stock o2 sensors to a plx dm-6 wide band o2 to run in closed loop configuration. Which wires in the digits input do I use to wire the plx to on the kpro to do this.
Aaron
Have you read the links above?
aaron johnson
If I'm reading correctly I would wire to the purple serial wire.
Do you have suggestions for grounding? Should everything should be grounded to the same point?
Correct, you will probably not need to us any ground for the signal. Just the switched power and ground for the controller to work.
