smooth 2D lines or constant AFR
janiscrulzz
Post by janiscrulzz »
i tune fuel in kpro. 2D lines looks bumpy but afr is 14,7 in part throttle and 12.8-13;1 wot. do i need to make 2D lines smooth or most important is AFR?
Re: smooth 2D lines or constant AFR
They should not be jagged. You can go through and artistically smooth them out.
janiscrulzz
When I smoot them out I take a look at datalog the AFR line is jagged. Whats better smooth 2d fuel lines or smooth AFR line?
In 2D map lines did not cross each other.
When done properly you should have both smooth lines and smooth AF ratio. Post your calibration.
janiscrulzz
Please take a look at low cam 2D fuel lines.
That looks ok
