s2000 kpro, does speed correction change gauge cluster readout?
RAIN H8R
Post by RAIN H8R »
For the VSS options, S2000 uses a countershaft VSS.
When adjusting the speedometer conversion option. If this is changed to either a + or - value, will the changes be seen in the gauge cluster or only internal kpro parameters for tuning?
I am in the middle of cleaning up/rewiring my ecu area after having my ecu upgraded from kpro2 to kpro4. It is the offseason so I am not able to test this out on the street due to salt/nasty road conditions.
2001 car with an AP2 transmission. I use the Modifry speedo healer to fine tune the speedometer readout in the gauge cluster.
Re: s2000 kpro, does speed correction change gauge cluster readout?
The ECU does not output a VSS signal to the cluster. The cluster gets the VSS signal straight from the VSS sensor.
RAIN H8R
Post by RAIN H8R »
Hmm, I called an Javier told me it does (before I saw your reply).
I will hold on to my speedo healer until spring when I can test this. But, if you say no then I expect it to do what you say.
