Security Setting issues
chrisbogart
Post by chrisbogart »
S300V2
I am having issues with using TPS % as security. It used to work fine, now it almost seems intermittent. I use a 80-100% I have re-read tps @ closed and WOT closed is -1.2%. I have tried other security settings and they work (not TPS)
Re: Security Setting issues
Have you looked at your TPS reading when datalogging with the engine not running to see if it is smooth or if it is choppy?
Mrgcd
Post by Mrgcd »
I just started having almost the same problem, had security set by tps and it seemed to work good. I uploaded slightly diff tune with same tps security settings and have no start, I try diff security settings such as brake or ac input and same no start, If i disable all inputs and uncheck use tps and re upload , cycle ign off then it starts up everytime. I have went back and forth with these steps several times and still same results. My tps in data log looks very smooth ign on engine not running as I press throttle tps % reacts smoothly up and down. Any help would be appreciated... Thanks
Please post the calibration you hare having trouble with as well as a datalog showing the issue.
