can i delete maf sensor replacing iat sensor?
urdaman
Post by urdaman »
hi can i replace the maf sensor to a iat sensor using afm calibration?
thanks
R-12914
Re: can i delete AFM sensor replacing iat sensor?
Post by R-12914 »
urdaman wrote:hi can i replace the AFM sensor to a iat sensor using afm calibration?
thanks
Nope!
But you can replace the IAT-Sensor from the AFM-Sensor with a separate IAT-Sensor to using the old AFM-Sensor with a new relocated IAT-Sensor!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
urdaman
Post by urdaman »
i still need a maf sensor? even if i have an iat sensor already?
Yes. The ECU still needs to have the AFM connected.
