Kpro 4 - EGT and A/F
iBoost
Post by iBoost »
Hey guys,
I'm in the process of putting my setup together. I have KPRO 4. I'll be running oil pressure and fuel pressure as analog inputs - I have those figured out. I'd like to have EGT and A/F as well.
Which EGT sensor/kit works best with KPRO 4? How is it wired? Sensors I've seen only have 2 wires.
Which A/F sensor/kit works best with KPRO 4? How is it wired?
Re: Kpro 4 - EGT and A/F
PLX Devices makes kits for both that will work very well.
iBoost
Post by iBoost »
Spunkster wrote:PLX Devices makes kits for both that will work very well.
So with PLX, I need to order their sensor and module?
That module then connects to Kpro 4?
That is correct
iBoost
Post by iBoost »
Ok, is below all I would need to order?
SM-EGT - EXHAUST GAS TEMP SENSOR MODULE
http://www.plxdevices.com/EGT-Exhaust-G ... 002184.htm
SM-AFR - WIDEBAND AIR/FUEL SENSOR MODULE
http://www.plxdevices.com/Wideband-O2-A ... 002726.htm
correct
iBoost
Post by iBoost »
Are they simple to wire up to KPRO 4?
