2016 Civic Turbo w/ Mishimoto intake calibration out?
ThatArsonist
Post by ThatArsonist »
Im new and i only see calibrations for the 3/6 psi w/ injens intakes. I went with the Mishimoto intake and was wondering if i load the calibration that goes with the injen intake will it matter?
typer86
Re: 2016 Civic Turbo w/ Mishimoto intake calibration out?
Post by typer86 »
Hmm... I can not recommend because I can not see the provided new calibrations of the 2016 turbos... I have only the FN2.
A good start point is to load a based equivalent calibration and fine tune it for your mods.
ThatArsonist
Yeah I tried going with the calibration of 6psi w/ injen intake anyways and after a day or two all my dash lights turned on like emissions, VISA, brake issue etc then the car wouldn't run correctly so I flashed it to the standard 6psi without any mods and car seems to run perfect for now. Not sure if a wrong intake calibration would cause all that
Here is the calibration which will be included in the next release of the software.
ThatArsonist
Thank you!!!
