Kpro V2 or save for V4
yaboiiiii
Post by yaboiiiii »
I found someone selling their rsx type s kpro v2 for pretty cheap. I was originally planning on getting the v4 but I could settle for v2 since its about $200 cheaper. Would there be any issues or major disadvantages to using kpro v2 over kpro v4? Thanks!
Re: Kpro V2 or save for V4
It does not have all the features and does not have Bluetooth. This is a decision you will have to make based on what features you will end up using. You may want to discuss it with your tuner.
yaboiiiii
Post by yaboiiiii »
Spunkster wrote:It does not have all the features and does not have Bluetooth. This is a decision you will have to make based on what features you will end up using. You may want to discuss it with your tuner.
I'm just doing bolt ons and maybe switching to type r or tsx cams. Will the Kpro v2 suffice?
It should as long as it is real and in working order.
For used KPro sales be sure to check this:
https://www.hondata.com/kpro-counterfeit
