K24a2 swap in 08 Si
Kbxm
K24a2 swap in 08 Si
Post by Kbxm »
Hello.
I was just looking around for a basemap to safely run my engine. Right now it's on the k20z3 map and I know that it is running lean( probably why vtec won't engage). I tried using the tsx tuned basemap but I realize that I can't load the map because of ecu.
TLDR: k24a2 tuned basemap for 08 civic si. Tried tsx tune it won't load.
P.s. Can I just try to copy and paste the entire tsx map into the civic si map? Will that work or will it give me the same message.
Almost forgot. Maybe someone might say just dyno tune it. But I live on a island where there are no dynos.
Re: K24a2 swap in 08 Si
You can try copying the ignition values , but you will not be able to copy and paste the fuel values as they are calculated differently. This will need to be properly tuned using a wideband.
Kbxm
Post by Kbxm »
Thanks. When I get home I'll try that right away. Be back if anything…
