Car wont idle correctly while moving
chrisbogart
Post by chrisbogart »
s300v2
b18c turbo
1000cc ID
IACV duty cycle in the middle @ normal
In the IDLE parameters i have my moving minimum idle set to 1500rpm but it does not work.
also if i adjust idle while stationary and upload nothing happens.
ive attached datalog recording
update: attached calibration
Re: Car wont idle correctly while moving
You have not posted the calibration that the datalog was made with.
chrisbogart
uploaded calibration
also, you can see in the datalog that when i let off throttle to coast, my fuel duty cycle goes to 0% and almost dies.
I don't actually see a problem in that datalog. The fuel injectors are supposed to shut off during deceleration, so that is normal. Have you set the idle per the factory service manual instructions?
chrisbogart
my idle adjustment screw is almost closed.
i dont understand why the minum moving idle drops below where its supposed to and never corrects
i didnt decel in gear, i simply put the clutch in then the rpms drop too low and duty cyle goes to 0% from 6.8 seconds on datalog to 7.3
With the car fully warmed up and idling, unplug the idle control connector and see what RPM it idles at.
chrisbogart
what will this determine? if my IACV is working or not?
To see if it is adjusted properly.
chrisbogart
So idle is adjusted properly. but the s300 still wont change idle and doesnt catch a falling idle when pushing clutch in.
with the IACV disconnected, what does it idle at?
forevertrj
Post by forevertrj »
chrisbogart, please tell us the idle RPM while the IACV plug is disconnected, don't answer with the idle is set right, if the screw is almost fully closed I guarantee it isn't set right. Please view http://www.hondata.com/help/smanager/se ... espeed.htm to better understand the reason for our question about he RPM value.
forevertrj
if the idle isn't correct when adjusting the set screw, while the IACV is disconnected, there is a high probability of a vacuum leak.
