Smoothing rev limiter
mladjan
Post by mladjan »
Hi,
I would like to smooth out stuff when I reach rev limiter, because rotrex don't like it :)
But before experimenting on the engine itself, is the best to use the same number for rev limit and rev recover? Will it keep it smooth or it will be best to use for example 8600 / 8300?
Re: Smoothing rev limiter
You will be much better off retarding the timing near the rev-limit as this will lower the power made and make it much smoother.
mladjan
Post by mladjan »
Cool, can do this as addition, but what is smoother, 8600/8600 or 8600/8300?
You will have to try the different settings to see what works best in your situation.
R-12914
Post by R-12914 »
mladjan wrote:Cool, can do this as addition, but what is smoother, 8600/8600 or 8600/8300?
If you have the limiter at 8600 rpms, then try 8500 rpms recover!
Note: The lower the difference, the softer!
BTW: I know, if the speed limiter would non-existent, the engine/Rotrex would still want further! ;-)
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
Best result (for my build) is 1:1...
I use currently rev limiter 8400 rpm and for recover 8400 rpm too...
