Bug in Bar Graph?
Place your display templates here with a screen shot of it for previewing.
creizlein
Bug in Bar Graph?
Post by creizlein »
Is it just me, or the Pointer Size property of the Bar Graph doesnt get saved on the Display?
I keep setting it to 8 or 10 and when Save and Load it gets reset to default 15
Also a quick view on the save file showed that the property is not stored on the file, so makes sense its not restored.
Is this a know bug, or at least is there any way to report it?
Re: Bug in Bar Graph?
Works ok here. What is the exact sequence you are following? Can you send us the .display file (to support@hondata.com)?
creizlein
Post by creizlein »
Sorry for the delay, i totally missed this reply.
I checked again, and no, it doesnt work
  1. I Load my display (attached)
  2. Edit the properties of the Bar Graph and set the Pointer Size to 10
  3. The Pointer Size DOES change to 10 as expected
  4. Save the Display and Reload
  5. The Pointer Size is back to 15
Please find attached display
Ok, thanks for the report. We have fixed this for the next release.
creizlein
Post by creizlein »
I can confirm now that the bug has been fixed, thanks a lot!
PointerSize now saves and loads properly on the displays !
