datalogging freezes
fabian_em1
datalogging freezes
Post by fabian_em1 »
so everytime my s300 starts datalogging it freezes all the time now, it used to never do that, i have my on board datalog to start at 3000 rpm, and when it starts it freezes around 3500 rpm- 4000 rpms and then it works again, its really annoying since i cant tune the engine very well since this happens, i bought a new usb cable like the one hondata provides but it does not help. any help would be appriciated
Re: datalogging freezes
What spark plugs are you using?
Turn off on-board datalogging if you are trying to datalog using the laptop.
fabian_em1
im using the oem spark plugs, and it does it even when the usb cable is not connected to the laptop.
i made a run with on board datalog on, then i hooked up my laptop and i check datalog and it only datalogged for 5 seconds, it froze between 3000 rpms and 6000 rpms after that it started working again, i already tried, different cable, different laptop, and same thing, something is wrong with onboard datalogging. Its really bugging me cause it never did this before.
fabian_em1
also my alternator output is kinda high, battery will be from 14.6-15v while the car running, i dont know if that affects anything?
The battery voltage could be an issue. I would recommend trying the ECU in a known working car and also try to resolve why your battery voltage is high.
Abide
Post by Abide »
mine started doing this today as well on the laptop. Onboard datalogging is off and plugs are BKR6E-11. sometimes it says online but doesnt update the sensors as well. my digital inputs refresh like normal just nothing from the ecu.
Is J12 cut on the ECU?
fabian_em1
J12 has to be cut for datalog to work probably?
It must be cut with any Hondata system, as it says in the installation instructions.
