Idle Issues
filo4u
Idle Issues
Post by filo4u »
Hello, I have followed all the steps that Hondata suggested in this post http://www.hondata.com/forum/viewtopic.php?f=12&t=4044 but still no luck. This idle issue is driving me crazy! While the surging happens I see that ignition goes from -1 to -10 is this okay? at first i thought it the TPS and tried to get it as close to -1 to 0 using a punch but ended up with 1.6. I have set this value in as the minimum on the TPS Scale would this still cause the problem? because when the surging happens it stays at 0% so i was hoping this would be okay. Thank you in advance!
Re: Idle Issues
YOu appear to have some other problem as the the ignition should not be doing what it is doing. Does it read cam and camcmd when not idling?
Bullyk20
Re: Idle Issues
Post by Bullyk20 »
filo4u wrote:Hello, I have followed all the steps that Hondata suggested in this post http://www.hondata.com/forum/viewtopic.php?f=12&t=4044 but still no luck. This idle issue is driving me crazy! While the surging happens I see that ignition goes from -1 to -10 is this okay? at first i thought it the TPS and tried to get it as close to -1 to 0 using a punch but ended up with 1.6. I have set this value in as the minimum on the TPS Scale would this still cause the problem? because when the surging happens it stays at 0% so i was hoping this would be okay. Thank you in advance!
your idle goes down almost to stop the engine?
