s300, random shut offs
red_teg
Post by red_teg »
Hi all,
I've recently been trying out my s300 on my integras to get used to the smanager software before I finish my build.
When trying on 1 car it would idle just fine and rev up no problems but was throwing a code 20 (electric load), thought nothing of it until randomly the car shut off and I was not able to start it again on the s300. Plugging back the stock ecu it would start no problems and idled just like it used to.
Trying to make sure it wasn't the first car's problem I've just now tried running it on another car. It also threw a code 20, and randomly shut off after a couple of minutes idling. I was able to start it again and went for a drive with no problems, but later on it died out of nowhere! The engine completely shut off, lost steering but managed to get it to the side of the road. The car was unable to start after several attempts, luckily I brought the stock ecu with me and just like the other car it worked just fine.
Surely there must be an issue with my s300, but It's hard to tell since the datalogging and all other functions worked fine. Any ideas?
red_teg
Re: s300, random shut offs
Post by red_teg »
Some information:
- Serial Number: S300-1218
- Software Version: 2.5.5.0
- Calibrations: both stock b18b and b18c (engines are mostly stock)
stockp74.skl
stockusp72.skl
- Datalog: Unfortunately didn't save any
- Vehicles: 1994 DC4, 1997 DC2 GSR
- ECU: Hondata s300
- ECU affecting Mods: Both cars have exhaust and intake
Without a datalog it is hard to say what it might be. That s300 is 11 years old, so that could be part of the issue, or it could be the ECU has a problem as that is over 20 years old. You might try replacing the capacitors on the ECU: https://www.hondata.com/accessories/capacitor-kit
red_teg
Post by red_teg »
Thanks for the reply.
I've opened it up and had a look, definitely can see a tiny amount of leakage from one of the capacitors on the ecu.
Think it's worth putting the s300 on a fresh ecu? or just cleaning it up and replacing the capacitors?
Replacing capacitors is pretty much mandatory for all the ECUs now for reliable operation, so if you do switch to a new ECU I would replace the caps on that as well.
red_teg
Post by red_teg »
I'll replace the caps and see how it goes. Thanks for the help
