do i need to disable FTP?
JackSVM
Post by JackSVM »
im running an ep3 turbo and i have a walbro 255lph pump running custom -6an lines and a return line (stock is non return).
my fuel pressure is now governed by the FPR so do i need to disable anything in the kpro settings?
im not sure on how the fuel pressure is regulated on the stock non return system.
ALSO
iv chopped the wires for the EVAP to use on the hondata boost controller solenoid so do i disable anything for this also?
help is greatly appreciated
thanks
jack
Re: do i need to disable FTP?
You should not have to do anything special in the calibration for either of those.
JackSVM
Post by JackSVM »
Ok thank you!
