Flashpro Manager 2.6.4
urbinac27
Post by urbinac27 »
Hi,
So i see that permissions are now able to be applied to calibrations. Can the Permissions be set so its drilled down leaving some options available? Example, Set permissions so things like, Fuel low & high, Ignition low high, and Cam angle low and high, be hidden but leave options like sensors and rev limits available to the user to modify? By Design when permissions applied the entire calibration is unavailable and may leave some people unable to shut misfire detection off on a weekend doing a clutch job and there tuner is unavailable as an example. Or If a Drag racer is racing on the weekend and finds that a rev limit isn't enough to clear the quarter mile and needs to be raised to finish in a particular gear.
Re: Flashpro Manager 2.6.4
For complete details on how the permissions work you can go to the help file: https://www.hondata.com/help/flashpro/c ... meters.htm
