06 rsx-s New kpro installed with 02-04 primary o2
Yangson720
Post by Yangson720 »
I just purchased a kpro on ebay for my 06 RSX type s and I bought an 02-04 primary o2 sensor on ebay from the same person who sold me the kpro. When i plug the new ecu in, my a/f ratio on the "display" tab reads around 11.7:1 and then spikes up to 32.6:1. I was using the "k20z1-rsx-2006.kal" basemap. Here is a list of mods I currently have:
megan race headers
Rbc intake manifold w/hondata gasket
Injen short ram intake
HKS Hipower full exhaust system
Everything else is stock on the car except for the suspension and motor mount inserts and stage 2 clutch. I took the secondary o2 sensor off and plugged it. I need to know which base map to use based on my mods and if the o2 sensor is the correct one and if the current base map is the correct one?
Re: 06 rsx-s New kpro installed with 02-04 primary o2
What is the serial number that is on the K-Pro board inside the ECU? Who was the ebay seller you purchased this from?
Yangson720
Idk the s/n but when i get back from vacation ill let u know. The seller is bestparts4u
