Speedo calibration
miahjera04
Speedo calibration
Post by miahjera04 »
I'm running 245/55r15s up front. Speedo is off of course. Been debating on goin the Speedo healer route. I've seen speed settings in Smanager. Is there anywaybtp correct the Speedo through Smanager?
Re: Speedo calibration
The signal goes from the transmission to both the cluster and ECU. You can correct the speed in the ECU but this does not affect the cluster.
miahjera04
Oh ok, thanks! Speedo healer it is
forevertrj
Post by forevertrj »
can he not add a varistor inline to adjust the voltage output from the speed sensor into both the ecu and tachometer?
It is a frequency pulse. You would need a frequency to frequency converter, not a voltage divider.
