Help
firelu21
Help
Post by firelu21 »
i do not know how to read data logs anyone know if this is acceptable knock retard? please and thank you.
i have a 2017 civic sport 1.5t i am running the injen +6psi map with 93oct
Re: Help
6 degrees retard would not be unusual. What are you trying to do?
firelu21
Re: Help
Post by firelu21 »
well, I have a SR intake (not Injen), intercooler with 2.5 piping, AEM Chargepipe. And was just wondering with this map if i was huring my motor
Re: Help
The ECU is good at managing ignition & knock. However, if' you've done anything to the air flow meter, like replacing the intake, then the air fuel can be off. I'd suggest getting a dyno tune. At the least post a datalog here so people can check the lambda for you.
firelu21
Re: Help
Post by firelu21 »
Not sure how to post a datalog
Re: Help
1. Make a datalog. You can do this from a laptop or from the FlashPro by pressure the datalog button on the FlashPro. The FlashPro datalog is better as it has a higher update frequency.
2. Drive around for a while. Get some full throttle and also normal driving in.
3. Put the FlashPro into a computer, open the FlashPro window, go to datalogs, then right click and save the datalog to your computer.
4. Post on this forum and add the datalog as an attachment.
firelu21
Re: Help
Post by firelu21 »
Thanks i will try it out this weekend.
