Skunk2 pro 90mm throttle body map and tps
Bruce Huang
Post by Bruce Huang »
My engine is K26, EK K swap, ecu is kpro 3
I bought a skunk2 pro 90mm throttle body, but the map hole is B series, what can i do?
1.B18c map and tps alternative
2. hole drill big use k20a map
If I use B series map and tps can i adjust it with kpro 3?
Re: Skunk2 pro 90mm throttle body map and tps
The B-Series and K-Series MAP sensors are electrically the same. You don't have to do anything if you switch between them.
