Aem ect gauge analog input for s300
miahjera04
Post by miahjera04 »
My ecu always gets false ect readings from old wiring. Brand new ect sensors and plugs, my temp gauge is functioning properly, the other sensor that sends temp reading to ecu has dry rotting wires and throws cel's for overheating. Can I run some type of wire from an aem temp gauge to an analog input on v3 board to bypass the reading from oem sensor to correct this issue?
Re: Aem ect gauge analog input for s300
No, you will need to fix the damaged wiring and use the OEM sensor.
miahjera04
Ok, guess I'll be rewiring that whole leg of the harness... fuuuuuun
