High Knock while Reving
techboii340
Post by techboii340 »
02 rsx type s
I/h/e
a/f radio cant be read , stuck in 14.7:1 , i get code p0134 , sensor is connected fine wires are ok ,i have more then 200 knock when i turn on the car it will start counting up to like 50, while it idle no count , when i rev it while at a stop the knock will go up crazy every time i accelerate the car, please any advice.
Re: High Knock while Reving
You either have an issue with too much ignition and are getting knock , or something is loose some where and it is picking this noise up as knock.
