Analog input settings
SanfordBuilt
Post by SanfordBuilt »
I am trying to set up 2 of my analog inputs A0= Oil Pressure and A1= Interstage Boost
I am aware that a custom sensor should be set up in bar. I believe I did that properly, but I am still finding that they aren't reading out properly.
A0
Oil Pressure
AEM 30-2131-150 - 150 PSIg Brass Sensor
Custom Input: 0@0.5V and 10.34@4.5
A1
Interstage Boost
AEM 30-2131-50 - 50 PSIa or 3.5 Bar Brass Sensor
Custom Input: -1.01@0.5V and 2.43@4.5V
Do these values seem to be correct for how I am trying to use them?
Compound Turbo (Added sensors).kal
Re: Analog input settings
Looks ok. Change the analog inputs to 'Raw Voltage' and check the voltage looks ok. Then change to a custom conversion with a 1:1 voltage conversion and check that.
