Cpr no sync light
Diegoormeno13
Cpr no sync light
Post by Diegoormeno13 »
If the dizzy when bad or something will I get a no sync light car has power n ign light flashes but no sync light shop has checked wiring 2 to 3 times n nothing is wrong please if I could get some help on this would be appriciated thanks I have a p28 v2 ecu with the latest software
Re: Cpr no sync light
Have all 3 options been checked for the CPR in the calibration?
redcar
Post by redcar »
Ive been wondering the same thing. I cant get mine to sync but it used to before...same ecu, same hondata cpr. trying to rule things out now
Have you tried the troubleshooting steps at: http://www.hondata.com/help/cpr/troubleshooting.htm
redcar
Post by redcar »
I have.... I'm just wondering if a bad distributor will cause sync problems....does it?
It could if one of the sensors is not picking up or sending the pulses correctly.
Are you sure Q37 is installed?
redcar
Post by redcar »
Yes, the resistor is there. I've looked 100% and it's ran before. Cars been sitting for awhile so just wondering if maybe the distributor is no good.
It is a possibility.
redcar
Post by redcar »
If I was to check voltage while cranking...what should I be reading at each pin out?
You cant check voltage as it is a pulse. You would need an oscilloscope to properly measure it.
