Can 37820-PND-Q01 compatible with K-Pro?
CHB
Post by CHB »
Hi guys,
Just bought a project 2001 Honda Integra DC5 K20A3 Manual 5 speed base model. Can anyone confirm if 37820-PND-Q01 ECU compatible with Hondata K Pro?
Every reference about Honda DC5 / Acura RSX I can found on the net all starts from year 2002.
Cheers
Paul
CHB
Honda DC5 2001 with 37820-PND-Q01 ECU compatible with Hondata K Pro?
Post by CHB »
Hi guys,
Cheers
Paul
Re: Can 37820-PND-Q01 compatible with K-Pro?
Do you mean 37820-PRD-Q01?
It depends. You will need to open up the ECU and post a photo of the inside, including the processor number.
CHB
Post by CHB »
It is 37820-PND-Q01. Photos as attached. Not sure which one is the main processor but I did notice that one IC is NEC, all others are Keihin.
Does the large square chip on the ECU say L66Q592 or L66592?
CHB
Post by CHB »
L66Q592
Yes, that ECU can be used.
BerKo
Post by BerKo »
Sorry for the old thread revival. Just wondering/confirming if L66592 (which my ECU is) is not compatible?
If it does not have the 66Q592 processor then it can not be used.
A PND-Q01 is not compatible as it is missing some circuitry and will give errors and not work correctly.
It is the same as a Japanese PND-J01, and is also not compatible.
