OBD2 Wiring
polok
OBD2 Wiring
Post by polok »
Hi,
Does have anybody the wiring pinout from ECU to OBD2. I have a Kpro ECU and a K20a2 without CAN. After swap in a Elise I have only connected pin 4 ground,5 ground,7k-line and 16 battery of OBD2 plug. Unfortunately in this case I got no connection with ECU in Torque Lite.
Re: OBD2 Wiring
That wiring is correct. Double check you have the pin numbering correct, then try a different scan tool.
polok
Re: OBD2 Wiring
Post by polok »
Shall I cut the remaining OBD wiring from Lotus ECU like PIN 65,79 etc.
Or it doesn't matter and I could save work
Re: OBD2 Wiring
Is the Lotus ECU still connected?
