Lambda Overlay and Fuel Adjustment Tables Always Blank
bdtan
Post by bdtan »
HI,
My KPro v4.3.3.0 has always shown blank tables when I view the Lambda, Lambda Overlay and Fuel Adjustment tables.
How can I get these to display?
Thanks,
Ben
Re: Lambda Overlay and Fuel Adjustment Tables Always Blank
They will only work when you use an external wideband input into the ELD input.
bdtan
Post by bdtan »
I have my wideband connected via analog input #1. Will that not work? My ELD is taking the input from my Hondata Traction Control. Is there no way to run both the wideband input and the Traction Control simultaneously?
Do not use the settings under options settings for this. If you are using an aftermarket wideband input into the K-Pro analog input then you must make that selection in the closed loop settings tab of parameters. This is the only way it can use an aftermarket wideband as it would an OEM wideband.
hsitko
Post by hsitko »
Did you ever figure this out? i'm having the same problem. My cells are all blank...
without the calibration and datalogs showing the issue it is hard to speculate what it might be.
hsitko
Post by hsitko »
