LS-2 coils in S2000
antkouv
LS-2 coils in S2000
Post by antkouv »
I am looking into installing LS-2 coils in my 2006 european S2000. Are the specs of the OEM coils available to compare with the LS-2 coils? (dwell etc). And if not, is there an option in Flash Pro to alter these figures?
Re: LS-2 coils in S2000
Why are you wanting to change the coils? The OEM coils should be good up to 1000hp at least.
antkouv
Post by antkouv »
In order to have a larger spark plug gap. At 15psi boost (stock compression ratio) I have to re-gap down to 0.5mm
You should be able to run .025-.022 inch gap. What spark plugs are you using.
antkouv
Post by antkouv »
I had NGK BKR8EIX with OEM coils and changed to Denso IK24 with K20 coils.
