CU2 VTEC ON Datalogging Only
GohardOzCu2
Post by GohardOzCu2 »
Hi have a problem with VTEC on the supplied base map with my flashpro.VTEC only works with the flashpro connected and datalogging.
Re: CU2 VTEC ON Datalogging Only
Sounds like you may have a problem with grounds in the car. I would recommend that you unplug the FlashPro until you have resolved the issue.
