MAP tune problem
Touge_FN2
MAP tune problem
Post by Touge_FN2 »
Hello and good afternoon.
My problem is simple, I can't use map tune in my fn2. When it was stock and you clutch at any rpm (in car rolling like when you are approaching to a traffic light) it power off, not stay at normal idle.
Now, it has throotle boddy, intake manifold, exhaust manifold and exhaust system. When I try to use map calibration, all is OK but when I am pulling out: or I rev it until 2000rpm o more or the car turns crazy in revs... In car rolling all is OK. It is only leaving from stopped.
Using mass air flow calibration all is OK (but I want to know what is going on and use MAP because calibration becomes finer.
Any ideas?
Thanks a lot.
Re: MAP tune problem
Post the calibration and a datalog showing the issue.
Touge_FN2
Post by Touge_FN2 »
Hello.
I still do not have datalog to upload here. At the moment I can upload calibration.
Thanks.
Touge_FN2
Post by Touge_FN2 »
Hello.
Here you have two logs, one starting to move and the other is without gear, stopped.
Thanks a lot.
typer86
Post by typer86 »
Please record a 15 min datalog with your affected calibration. It is not possible to see what is happen in a short log.
Touge_FN2
Post by Touge_FN2 »
What??? 15 min datalog? It is a joke?
Spunkster, really need that?
R-12914
Post by R-12914 »
Touge_FN2 wrote: Wed Jul 05, 2017 2:25 pm What??? 15 min datalog? It is a joke?
Yes, a datalog time of at least 10-15 min. is necessary to be able to interpret the behavior optimally!
Where is the problem?
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Touge_FN2
Post by Touge_FN2 »
Problem? No one.
Sorry if my answer sounded rude.
It's just strange for me, never did it for 10 minutes... I just did datalogs one or two gears and stop it.
I will try to use the car in normal city traffic and put a log here...
Touge_FN2
Post by Touge_FN2 »
Hello again.
I upload latest datalog... I start recording from start up, 10 minutes aprox with normal traffic in the city central (crosswalks, traffic lights, etc).
Hopefully it will be useful.
Thanks again.
R-12914
Post by R-12914 »
Your Engine still runs very lean, if you drive.
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
It seems to be fuel Map table is not tuned. S.trim jumping into extrem lean conditions and the closed loop cycle can not handle it so fast.
I take further look into the calibration and your log tomorrow.
typer86
Post by typer86 »
I have checked the calibration with your log.
#1 Correct the VTC profile - it is very bumpy it is not necessary to use the bumpy start vtc profile - (it is hard to adjust the fuel tables if jumping around the different angles...)
#2 If you select "use map tables to determine fuel" edit the fuel-MAP tables - increase the values in your case the calibration is running very lean! (30 to 46% to lean!)
Touge_FN2
Post by Touge_FN2 »
Thanks for your fast answers!
I'm going to tell all of this to my tuner, I hope he can handle thatt info to solve the "issue". If we can solve it, I'll put here.
Thanks again.
