Kpro V4 Digital/Analogue Input & Output wiring
CHB
Post by CHB »
Hi guys,
Going to send my PND ECU for KPro V4 next week. Just today the dealer told me that the digital/analogue input and output wiring will be hard wired to ECU connector.
Won't that will delete some of the factory functionality of the wiring as the way they connect those additional 20 wirings for these additional input/output?
How was yours Kpro V4 get done? Did Hondata just let you guys plug in the supplied "10 pins pig tail x 2" onto the Digital/Analogue terminals on the "White Kpro V4" board or they hardwired them into the ECU connector?
Cheers
Paul
Re: Kpro V4 Digital/Analogue Input & Output wiring
I'm not sure what your dealers means. The analog & digital wiring are separate pigtails. You don't need to do anything with the ECU connectors, unless it is to supply a sensor with 5V.
