Fuel adjustment cells are blank
hsitko
Post by hsitko »
So i ran a data log this morning. I loaded up my current calibration and then loaded up my data log. I went to tables and went to low speed fuel and selected fuel adjustment from under the view tab. All blank cells. Went to high speed fuel with fuel adjustment selected and all blank cells but 2. Here is my calibration and data log. I'm running kmanager 4.3.3 (newest current).
hsitko
Re: Fuel adjustment cells are blank
Post by hsitko »
Also if i go to view and pick other view options like sensor overlay and go back to fuel adjustment sometimes another cell will have data in it. This really seems like an issue with the software to me. I read a thread here where someone loaded an older version of kmanager and this functioned correctly. Where could i find an older version to see if that theory is correct? Thanks.
Please post the calibration and a datalog showing the issue.
hsitko
Post by hsitko »
Weird. I posted them in the original post but they didnt stick...
k20a2-RBC-I-E-Keto.kal
keto 6-20-17 1st run just the pull.kdl
It works ok here. Check your options under 'Lambda Overlay'.
hsitko
Post by hsitko »
what settings do you have in settings under lambda overlay that make it work for you? Can you post a screen shot?
IT works with these settings
